06-06-2024 05:23
06-06-2024 05:23
On fitbit app, android, charge 6
Attempting to log sleep manually error comes up, "Can't save sleep session" "A sleep has already been logged in this time period."
However no sleep period shows, neither on the watch or app
I have tried the classic:
Log out
Turn off bluetooth
Force stop app
Restart watch
Turn off phone for 2 minutes
Turn on phone, bluetooth, log in, resync
As well as lesser versions of this. The fitbit almost never has an issue tracking sleep; the exception is when I take my watch off within 5 minutes or so of waking. Then it never will show me the data. The data must be there and that's why it's not letting me manually log it.
06-06-2024 12:34
06-06-2024 12:34
Hello @FitTravis
Sorry to see that you're having problems with trying to manually log your sleep.
Have you had a chance to clear the cache for the Fitbit app on your phone?
Another place to look for your sleep data is the on-line fitbit.com dashboard. If you're on a computer or tablet, you should see "Dashboard" at the top of the forum page between Help & Store.
Best Answer06-26-2024 06:59
06-26-2024 06:59
I had this same issue and tried your solution several times. I can see there is sleep data logged for a date that isn’t showing in the app. However, there isn’t an arrow for me to click to the right of the log. There’s nothing but a star at the top of the date. Do you have another solution?
01-26-2025 05:07
01-26-2025 05:07
Sorry to resurrect an old thread….I’m having this problem today so I tried a browser login on my tablet but it only prompts me to use the app. Any other ideas?
Best Answer01-26-2025 06:22
01-26-2025 06:22
As you can see I never did get any more tips on how to fix this. It’s happened a couple times since and I still haven’t solved it.
Best Answer01-26-2025 13:04
01-26-2025 13:04
Hello @AltaRAnderson & @BethSquared
The on-line Fitbit.com dashboard was still available when I provided those steps. The web dashboard was discontinued last year (2024).
Please provide some additional details on the problem you're seeing and what troubleshooting steps you've tried so that we don't repeat those.
My apologies if you've already reviewed the information & tried the troubleshooting steps on this help page: How do I track my sleep with my Fitbit (<-- click link)
I'm sorry that I didn't see your post and that no one replied to you. I'll do my best to help you.
Best Answer01-26-2025 16:21
01-26-2025 16:21
I followed all the steps in your original reply. I still couldn’t log my sleep manually. I got the same warning that it couldn’t be logged because one already existed. It has done it 2x since my post in June of last year. It’s not a regular thing….it seems to happen once in awhile.
01-26-2025 16:53
01-26-2025 16:53
01-27-2025 11:28
01-27-2025 11:28
When you get a message that you can't edit the log because one already exists, go back to the previous day's Sleep page & see if there's a log for that time under Additional Sleep.
I recently had a similar problem where I couldn't edit my sleep log for the same reason - a sleep log already existed. But, I couldn't see it on the Today's Sleep page. It finally dawned on me that I should check the previous day's Sleep page. And there it was! After I deleted that one, I was able to edit my log and get my full sleep tracking.
Hello @FitTravis
Like you, I've had to delete an entire sleep log and enter a new one with the correct start & wake times. Usually, it takes a bit of time for the algorithms to use the new data and update my sleep tracking, with score & sleep graphs. Sometimes, though, I only get the basic sleep graphs.
Best Answer01-27-2025 11:51
01-27-2025 11:51
Absolute genius, at least in my case. My sleep logged the day before. 🤦🏼:female_sign:
