Something Changed
as of November 6 weight updates no longer occur immediately but sometime during the day and my body fat percentage from 19% to 35% what happened?
2 REPLIES 2
@Sdjr   I moved your post to the Aria scale forum, a better fit for your issue.  Fitbit is aware of the time delay with your weight appearing in your weight tile.  This is happening to both Aria/Aria 2 users and isn't specific to Android or iOS.
I didn't merge your post into the existing thread, because of your second issue,  I don't have an answer for you.  Maybe someone else can help you.
This is a no, harm, no foul comment.  November 11 is in the future.  You can edit your post by doing the following.  Tap on the down arrow in the circle in the upper right of your post, then the Edit option.
Laurie | Maryland
I meant to type in November 8
