Hi @Redemma180 - I think you're talking about the on-device setting when you go to start to record a swim. Best I can tell, the on-device setting is to set the pool length units and doesn't affect what the app shows for your distance.
To set what the app shows, go to Fitbit settings -> App settings -> Units, and change it in the Swim section.
