12-14-2023 03:01
12-14-2023 03:01
Hello,
At the moment I have a Charge 2 and I am looking to upgrade it. I have been looking at the Charge 6 and the Sense 2. Both seem to have advantages and disadvantages and quite a lot of problems. Has anyone got thoughts about which might be best?
Thank you!
Best Answer12-14-2023 16:25
12-14-2023 16:25
My first thought is, what do you like and dislike on the Charge 2, Is their anything with the Charge 2 that you found missing? Is their anything that you really would like? Do you like the smaller footprint of the Charge line? Do you want the larger display?
As you see, it would be helpful to know your needs vs wants vs can't live withouts
Best Answer12-16-2023 13:55
12-16-2023 13:55
Hi, Thank you for replying. The Charge 2 has had most things I have really needed and wanted other than being able to swim with it. The reason I’m looking to upgrade is I want to have a tracker which is up to date and because after 6.5 years the chipped and cracked screen is starting to annoy me! I guess my most important considerations are that the replacement is reliable and will last a few years.
