06-12-2024 02:20
06-12-2024 02:20
Clicking on Gallery is of no use. Always says, No internet connection!
And There's no option for wifi
06-12-2024 03:11
06-12-2024 03:11
Welcome to the Fitbit community, @Rajkr!
Sad to hear that you're having an issue using your Fitbit app.
As there is no WiFi on your Charge 6, there must be a problem with the internet connection of the device you're using the Fitbit app with. If your mobile device is running Android, please have a closer look here to hopefully get things fixed:
Fix internet connection problems on Android devices
If you're using an iOS device with your Fitbit app, this might be helpful:
Connect iPhone to the internet
06-12-2024 03:11
06-12-2024 03:11
