08-06-2018 13:09
08-06-2018 13:09
All,
I've been doing really well with tracking calorie intake in regards to my budget, but I'm really struggling with mixed nuts! I just don't understand how they can be compatible with the budget. In other words, I don't feel they should be included in the budget. Or, at least there's more to it than meets the eye.
For example, I just downed 105g of mixed nuts for an afternoon snack. According to the label, that's 607 calories! Slightly more calories than a McDonald's Big Mac.
Doing some initial research, it appears that nuts are a very healthy snack and don't attribute to weight gain:
https://www.healthline.com/nutrition/nuts-and-weight-loss
It also sounds like the body only absorbs so much:
https://community.fitbit.com/t5/Eat-Well/Do-you-weigh-your-nuts/td-p/1213109
Even still, let's say 70% absorbed on average for mixed nuts. That's about 425 calories based on my original 607 calorie count. Not that far off from a Cinnabon MiniBon Roll at 380 calories.
To the point, I'm a little confused as to if I should or shouldn't be counting calories from a snack of mixed nuts. Is there anybody here who would suggest not counting nut calories towards the calorie budget? How should I approach this?
08-06-2018 20:45
08-06-2018 20:45
Yes they should count toward your total Calories. Nuts can be good for a diet, but they have to be the right nut. Almonds, cashews, Pistachios, walnuts, and brazil nuts are the best for a diet. Unfortunately mixed nuts also contain Peanuts and Pecans. And 105grams is like 5 times the serving size of most nuts. I would cut back on your portion size and switch to a better nut. I eat a 17.5 gram bag of Cashews and it is only 100 calories and it does satisfy me.
08-06-2018 20:45
08-06-2018 20:45
08-07-2018 11:03
08-07-2018 11:03
Yes, of course you count the calories.
As you’ve noticed they can add up quickly, so you’ve got to watch the amounts. But 15 - 30 grams for 100-200 cal can really round out and make satisfying a salad or oatmeal or yogurt and be the difference in making one meal last to the next.
Scott | Baltimore MD
08-07-2018 11:25
08-07-2018 11:25
CVS has a great nut mix that's just almonds, pistachios, and cashews. It is my favorite nut mix. I sometimes eat a handful of that with a few dried apricots as a midmorning snack.
08-07-2018 18:10
08-07-2018 18:10
I stopped eating nuts when i started dieting as they are too high calorie and i can't control myself as i love them too much.Same as peanut butter .It has way too many calories.
