You should add a feature to the Aria where people can trigger the recalibration process by tapping the scale before stepping on. The reason this is needed is a lot of people can't, or won't, leave the scale sitting out in the same spot and it gets leaned up against a wall or put away in a cabinet after each use. Because of the this the tare/zero setting from the prior weigh-in is lost, but the Aria isn't smart enough to detect that and so it reports their weight, and body fat %, incorrectly for one or more weigh-ins. By adding a simple tap before stepping on to trigger the recalibration, "Sensing", "Step off", "Thinking" process, it would allow people that move the Aria to tell the Aria that it needs to recalibrate itself.
Of course, another option is to make the Aria smart enough to do it itself, but that seems to be a problem. It appears, and probably rightly so, that your engineers found that you get the best calibration by having the persons full weight on the scale prior to zeroing it hence the "Sensing", "Step off", "Thinking" process. Once that has been done it displays the weight as soon as you step on, and doesn't want to "change" that once you step off and it notices that it was wrong.
The last option would be to always go through the calibration process, meaning it never shows a weight until after you have stepped off. This would make the weigh-in process take a little longer but I think would provide more accurate and consistent results. (This could even be an option someone could enable in their scale settings.)
Moderator edit: Added labels.
Community Guidelines
Learn the Basics
Join the Community!
Go to the Help Site
Contact Support
