07-11-2024 12:18
07-11-2024 12:18
I might be missing something, but is there a way to disable settings, or put settings specifically behind a pin, so that my child don't accidentally turn things on/off (do not disturb, screen lock, other security settings, etc) on the watch directly?
07-11-2024 13:23
07-11-2024 13:23
I could be wrong, but if I'm interpreting your question correctly, then no, an option like that doesn't exist. You can always request that in the "Feature Suggestions" board.
one cruise ship at a time!07-11-2024 14:41
07-11-2024 14:41
Hello @g123try
Have you had a chance to do the firmware update for the Ace LTE?
Settings was originally accessed by swiping down from the clock face, which was way too easy for a child to access. After the firmware update, you have to hold down the grey button for the menu to appear, then swipe up to see the Settings icon. This change makes it less easy & intuitive to get to the Settings menu.
The idea of using a Parent or Administrator pin is a good one, though.
07-11-2024 15:58
07-11-2024 15:58
Yeah, I just did the update and I agree that settings is more hidden now which is definitely better!
