I really like my Fitbit Premium, however, I think it can be improved with these simple user friendly updates. I discovered some ideas after temporarily joining another app to compare:
1. Add a search capability to the workouts. Presently, they can only be organized by type, time and intensity. What if I'm looking for a specific one for targeted areas or a specific trainer? Hard to do.
2. Allow some of the challenge exercises to be saved or favorited to be able to do them again.
3. Add the calorie burn amount to each exercise to help with their selection.
4. Bring back the algorithm previously used for Fitstar Personal Trainer to automatically suggest the next exercise based on what the user had completed. This was the best and most unique thing Fitbit had before Google took over. It also saves the user time from having to search or knowing the next best exercise to choose.
5. Add a "calorie density" (CD) score (food calorie divided by its weight) to each food log for the quality of nutritional value to help with weight management or reduction. This can be done by putting foods in green (best - lowest CD) to yellow (medium CD) to red (highest CD)
6. Speed up the very long delay it takes to search and log many foods.
7. Add an ingredient search for the recipes.
8. Recipe movies should also have text instructions, ingredient amounts + calorie and CD count.
Hope these will be considered. Many thanks!
