09-24-2020
08:06
10:42
SilviaFitbit
09-24-2020
08:06
10:42
SilviaFitbit
Is there no way to disable music by default? I don't like the music selections at all and prefer to workout without music anyway. It seems awfully presumptuous to assume that everyone wants to hear the same music during workouts.
Also, is there any way to disable audio congratulations at the end of a set? They are cringey and unnecessary.
These settings should be available and easy to find for a premium feature.
@SunsetRunner A warm welcome to the Fitbit Community. I'll be happy to clarify your inquiries.
If you're doing Fitbit Coach workouts, it's possible to disable music, check the instructions on this article: About Fitbit Coach.
The setting that you could change are rep ticks, audio mixing which enables mixing to crossfade between your coaching tips and Fitbit Radio. However, the congratulations message at the end are part of Fitbit Coach and can't be disabled. Your feedback is always welcomed, this is why you could post your idea in our Feature Suggestion board, those are reviewed by our team and the status will change depending on Fitbit plans.
I'll be around if you have any additional questions!
