My fitbit has given me a sleep score reliably for months - until this week. I still get sleep stages. I can see my heart rate through the night, but no sleep score or the other information that goes with it. I have uninstalled and reinstalled, updated app, force quit and restarted phone, nothing works. I never noticed before but this stuff isn't available on the website.
Best Answer@RVA2022 Do you still have Premium? Sleep Score is only available with Premium, so are you sure it is still active? Do you have a Daily Readiness Score?
@RVA2022 Try removing the sleep tile and re-adding it. You can remove it by tapping the Edit button in the upper right hand corner of the app and then tapping X on the sleep tile. Then tap Done. Tap Edit again and scroll down to the bottom of the app and you can add the sleep tile back.
It may take another night of sleep, but see if that resets it going forward.
