09-09-2021
19:20
13:38
SilviaFitbit
09-09-2021
19:20
13:38
SilviaFitbit
I bought this Fitbit based on the services it included out of the box. I found it valuable to check my sleep pattern. Then Fitbit stopped providing those services and decided that I should now pay them monthly to continue getting my original services. So I can no longer see my sleep data- it just stopped. I’ve never seen a company take away elements from your current purchased product.
I will not buy another Fitbit.
Best Answer09-09-2021 19:31
09-09-2021 19:31
Hi @Thor2233 you don't need to pay for Premium to get basic data. For those wishing to delve more into their sleep and activities, Premium gives more detail. Did you purchase Premium or were you using the free trial that comes with many of the models? Which Fitbit do you have?
07:55
13:39
SilviaFitbit
09-10-2021
07:55
13:39
SilviaFitbit
09-10-2021 13:46
09-10-2021 13:46
@Odyssey13 Thanks for the assistance provided.
@Thor2233 Hi there. Thanks for the detailed information shared.
I see where your disappointment is coming from. I appreciate that you've been a Fitbit user.
The sleep data that's part of Premium is the analysis of sleep duration and the analysis of sleeping heart rate & restlessness. The percentage spent on each stage is still available in the Fitbit app, to check it out follow these steps:
- Go to the Fitbit app
- Tap on the Sleep tile
- Select a sleep graph
- Choose Deep and REM > The percentages will be displayed
Also, please let me know if you're getting sleep stages and not only sleep patterns.
Hope this helps.
09-13-2021 07:04
09-13-2021 07:04
Those steps were not working for me. I had access and data up until May 18, 2021, and then the sleep logging stopped working.
Best Answer09-13-2021 11:11
09-13-2021 11:11
@Thor2233 Thank you for getting back.
The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
See you around.
