09-05-2022 04:31 - edited 09-05-2022 04:34
So im just curious and i wanna make sure im not cheating myself , my treadmill says i've burn 84 calories but my fit versa 3 says ive burnt 294 calories , im guessing the treadmill is only going on distance and my fitbit is going on heart rate , bmi , and other info ive logged in , I was 24 stone 6 pounds im now 23 stone 1 pounds , so ive lost a massive chunk of weight already , but if the calorie losses are correct by the end of the day when ive done all 3 sessions on my treadmill , ive lost over a 1000 calories , just from walking fast on my treadmill.
Thanks all.
09-05-2022 08:05
09-05-2022 08:05
Hopefully someone can help ,ill keep this bookmarked
09-05-2022 08:49 - edited 09-05-2022 08:51
Can't really answer without knowing more about your treadmill, but suspect fitbit is more accurate. But also you didn't say anything about how long your 84 calorie walk was so we really can't judge what number is reasonable.
Some treadmills input lots of information such as weight age, sex, etc; others don't know anything about you and just make a wild guess based I guess on some "average" person.
If yours is the latter, definitely trust the Fitbit; but probably trust fitbit more in either case; but remembering that FItbit calorie burn is based on heart rate, so just occasionally check that heart rate readings look reasonable.
09-05-2022 09:27
09-05-2022 09:27
Rebook Jett series 100 , 20 minutes 3 times a day , my treadmill doesn't have any of the functions you mentioned apart from the heartrate which i dont use as i have a fitbit. And thanks for the response 🙂
