07-15-2017 17:37
07-15-2017 17:37
I had to replace my charge hr and the directions to sync it say to click the account icon on the fitbit dashboard, but I can't find it. Any help would be great.
07-17-2017 10:52
07-17-2017 10:52
Welcome to the Forums @SueR67! Hello @SteveH.
I agree with @SteveH, it seems like you got information about the Fitbit app's dashboard and not the online one. To get the software needed to sync through your computer you can click here.
Let us know if you have any questions or need any further assistance.
07-15-2017 23:59
07-15-2017 23:59
I think the directions you found relate to the fitbit app.
If you are using a computer then you need to use the fitbit connect software rather than the dashboard. You should have a fitbit icon at the bottom right of your PC screen near to where the time is displayed. If you double click this you should see an option for adding a device.
07-17-2017 10:52
07-17-2017 10:52
