04-29-2016 23:51
04-29-2016 23:51
I have read and tried the solutions for changing start date several times, but even though I change the date and "save", it insists my starting date is April 19th.
04-30-2016 07:49
04-30-2016 07:49
Hey @annembrus is great to have you here! Do you mean the Personal trainer? or logging activities? Do you think that you can share a screenshot with me?.
Lets find a solution!
If this post was helpful vote for it or accept it as a solution! Remember challenge yourself and become better than yourself. Share your story!
05-01-2016 01:31
05-01-2016 01:31
I go here, I choose edit, I change date to Feb 14th and log my weight, I save and I am back to the same picture as below. Same date as before it was changed.
05-03-2016 14:35
05-03-2016 14:35
Hey @annembrus thanks for the screenshot! First try to Clear the Browser Cache on your computer and after that follow the instructions on this article to change your information "Weight Goal".
I hope this helps, let me know how it goes!
05-04-2016 03:50
05-04-2016 03:50
Well, it sort of worked. I thought I'd be clever and do the change at work, and avoid the problem at home. It worked fine. But then I realized I had plotted the wrong weight in, and tried to change it (still at work). That did not work. Then I deleted all temp. files etc. and was back to April 19th and square one. I have now tried to delete history and cockies and the lot several times, but still April 19th and not possible to change.
05-04-2016 15:24
05-04-2016 15:24
@annembrus. Just a question, which browser are you using Google Chrome or Internet Connection?. Because the quality and definition of the Fitbit Dashboard in Chrome it is better than Internet Connection. Finally, as a last resource try to uninstall and reinstall the Fitbit Connect program and after that sync your tracker.
If the issue persist, try to contact Costumer Support, they have the tools to further investigate this issue and I'm sure they will help you.
01-29-2018 09:05
01-29-2018 09:05
I've been racking my brain because I knew I have done it before. Open the fitbit app. Click on your profile in upper right hand corner. In "account" scroll all the way down to "Nutrition & Body". In that screen you can change your start sate, start weight, what your goal is etc. Hope that helps.
