09-03-2018 13:32 - edited 09-03-2018 23:34
One tile will not load in my dashboard. Tried multiple devices and browsers.
09-03-2018 21:43 - edited 09-03-2018 21:43
@krist0ffers3n Hi and Welcome - is this on the Mobile app or the Desktop/laptop version or all devices as you mentioned - when you say will not load is it there but just showing a download circle or is it not showing as a tile at all (as in missing) - the only suggestions at the moment are to un-install and re-install the app if on a mobile devices - or on a desktop/laptop log out of Fitbit clear cookies and cache on your browser and log back into the site again
if this doesn't work then customer support may give you some more suggestions the phone number will appear once the office is open (usually 0800 - 1900 Mon-Fri and 1000 - 1700 weekends in the UK)
This is for the UK but should you need to change country scroll to the bottom and look for United Kingdom with a down arrow next to it and click on the arrow now you can select your relevant country and the page will refresh
hope this helps
Kind Regards
Wayne
09-03-2018 23:13
09-03-2018 23:13
It's on browsers on my laptop. It just shows a spinning download wheel. I've already tried clearing all that. I'll try calling support. Jakob
09-03-2018 23:26
09-03-2018 23:26
@krist0ffers3n sorry I could not have been of more help - and apologies when I first responded I could not get the screenshot you provided so couldn't see exactly the issue - occasionally if I get this I refresh the page and it works ok like I would go to log the back to dashboard and it loads correctly you could try and add another tile to see if that helps or has the same issue, also if you are using Fitbit connect you could see if there has been an update to the connect software and update it which may help although I believe this is just a gateway to aid with the syncing of the device
fingers crossed and hope support can help - please let us know if and how they fixed it to aide others with the same problem should it arise again
All the best
Wayne
09-04-2018 01:54
09-04-2018 01:54
I believe it's a known issue, @krist0ffers3n. Fitbit have said they will fix it at some stage. It's been a while since they said that (in my case). There are probably more urgent matters occupying them.
09-04-2018 04:30 - edited 09-04-2018 04:31
@SunsetRunner unfortunately that is the thing with Fitbit they are always aware of issues and working strenuously to fix them but they do take a long time to rectify if ever the issues I am waiting on have a range of 6 months to 2 years and still no fix although they have been aware since first reported - what can be more important to a tech company then ensuring that the product both hardware and software works properly - bringing out new devices and re marketing is a pointless endeavour if the needs of the customer are put to the side as a we will get to it when we can be bothered attitude will not give them good ratings or increase sales.
there cannot be anything more urgent unless the building is on fire or is getting flooded
so just be aware that at some point maybe never
I don't wish to be negative because the devices really are good its just the software and support that really needs to be brought up to date and not constantly blame it on the customers App or web browser etc
