08-24-2019 09:19 - edited 08-24-2019 11:26
The app has become erratic. Doesn't load or sink as well anymore, sometimes not at all. Disregards selected workout function. Why rely on it if it fails to update?
Update. As of this moment in time, it hasn't sinked in the last 12 hours. Not acceptable.
08-24-2019 14:19
08-24-2019 14:19
I did as you suggested and it appears to have solved the issue. Thanks for your advice. Film at 11:00.
08-24-2019 14:08
08-24-2019 14:08
Azkobushi it sounds like your app is really giving you tons of trouble:double_exclamation_mark: How frustrating that must be! I hate to offer the “go to answer” about deleting the Fitbit app completely and reinstalling it to see if that might work but maybe it might in your case since it sounds like you have multiple issues. Not syncing in 12 hours is obnoxious! I can’t offer anymore help but that but if you decide to call customer service directly for support I’m sure that is something they are going to recommend so maybe beat them to the punch and do a reinstall first so if it doesn’t work MAYBE they can go into their “bag of tricks” to offer you a better solution. Good luck to you.
Happy Stepping 👣👣
08-24-2019 14:19
08-24-2019 14:19
08-24-2019 14:22
08-24-2019 14:22
That’s awesome news Azkobushi:double_exclamation_mark: I’m happy I could help 😃
