02-27-2020 10:57 - last edited on 03-15-2020 15:09 by LiliyaFitbit
I am having troubles with my fitbit Alta can anyone help me??
I sync it 2 weeks ago,hoping my issues will be solved. but no avail.
not sure if its the battery or any other internal problems.
when I tapped it no signs of life, then I plugged it in and it shows the battery life is almost full, but nothing is showing on my fone in the App.
I contacted Fitbit Team for help for months now but no sign of it working.
Please help me....
02-28-2020 07:41
02-28-2020 07:41
Hi, @maureen499 , have you tried giving your Alta a restart?
Here are the instructions:
It’s worth repeating this procedure a couple of times, as a single restart does not always do the trick.
