Fitbit connect
ANSWERED
Where can I find the fitbit connect software so I can download it?
I recently had to get a new computer (PC) and as part of the change my fitbit connect has gone.  As a result I can no longer sync my fitbit charge 2.
1 BEST ANSWER
Accepted Solutions
For Fitbit Connect for your computer you need to go here. Scroll down and select the one for your computer
https://www.fitbit.com/start
Community Council Member
Wendy | CA | Moto G6 Android
5 REPLIES 5
Hi @DaveRapson
Download and install the Fitbit app from one of the following locations:
You can read more about how to set up here - click
Let us know how things go for you.
Congrats on the new computer!
Stepping in the U.S.A. since September 2013. Android 14
That worked for a couple of days BUT THEN, 2 days ago, it suddenly stopped working.
The App is still installed on my PC.
The App fires up ok and displays the usual 'dashboard' page but then after about 2-3 seconds the App terminates, no messages, warnings or anything, the App just closes itself down.  I don't get time to look at anything.
Any ideas?
Now you  talking about the  App are you using win 10 to sync?
Fitbit Connect is a program that is installed on your computer. If this is what you are talking about is the dongle plugged in? If so move it to another USB port and see if it syncs
Thanks for your input so far.
Yes I am using Windows 10 and the App.
I am aware that Fitbit Connect is a program.  I used to have it installed on my previous machine and everything would work just fine (right click, sync and so on).
Connect is not on my current machine but the App seemed to Sync with my wearable for the first couple of days - but then this 'fire up and quickly close down' situation arose.  I have no idea why I have moved the dongle to another port with the same result (and also moved it back again).
The PC says that the dongle on the USB port is working
If you know where I can load the Fitbit Connect program from I would appreciate going back to that.  Your previous link led me to a site which wanted to load the App (which was already loaded and seemed to work for a little while.
