03-14-2018 08:43 - last edited on 03-15-2018 07:15 by LanuzaFitbit
I am so sick and tired of this **ahem** system not syncing. I've seen the message board and see many other people with the same problems. Why can't Fitbit fix their system. At least put the button to force a sync on the dashboard. Use some common sense.
I will not recommend this product.
Moderator edit: Clarified subject, format
03-15-2018 07:59
03-15-2018 07:59
Hello @gct.
I definitely understand your frustration, allow me to help you out.
Could you please go a bit more in-depth into what is happening? What device are you using to try and sync? What Fitbit do you have? Do you receive some sort of error message? When did it start happening?
Look forward to your reply.
03-15-2018 21:32
03-15-2018 21:32
I have a fitbit zip. It stopped syncing on Monday at 7pm, and has not moved since. Most annoying is when you send a message saying that I should synce it. Why has the company not taken care of this? I am very disappointed with the entire operation. Please advise
03-15-2018 23:30
03-15-2018 23:30
My brand-new (arrived today) Fitbit Flex 2 also hasn't synced since 6:15 p.m. It's now 11:30 p.m. It doesn't seem to be registering anything. I'd appreciate advice on how to fix the problem. Thanks.
03-16-2018 06:31
03-16-2018 06:31
Welcome to the Forums @cb73. Hello @abcameo.
That sounds very bothersome.
@cb73, please try to follow these steps to get your Zip to sync correctly. Be sure to follow the steps on the order that they appear.
@abcameo, I replied to you on your thread. Thanks for sharing your concerns.
If you have any questions, please let me know.
