03-29-2020 14:49 - last edited on 10-14-2021 15:09 by CindyMFitbit
I do a lot of workouts under martial arts... is there a way to custom make a workout e.g. dance, body combat, sh'bam (I'm a les mills user). Can we rename workouts either on the website or in the app? And if so, how? I cant always remember what I did and need to be ab;e to differentiate.
04-01-2020 15:05 - edited 04-01-2020 22:01
@Itsreem55 On the computer Dashboard Under exercise if you scroll over to the left you will see a Pencil. This is for edit. Use that to rename your exercise.
Phone just tap on it and you should see how to rename it.
Create Custom exercise. Scroll to the very bottom of the activity screen on the computer and you will see Create Custom exercise. Click on it and a screen will open up and you can name and add what ever you want. I will save it as a favorite so it easy to find. So you can have your Body Combat as a Custom and rename it. I like know what I did so have several Custom exercises
This can not be done in the app that I know of
Wendy | CA | Moto G6 Android
03-29-2020 22:47
03-29-2020 22:47
To rename them you need to use Workout mode when you start.
You will need to set up custom ones for what you are doing. Once it syncs you can rename them
03-30-2020 00:55
03-30-2020 00:55
03-31-2020 10:48
03-31-2020 10:48
@Itsreem55 Which Fitbit model do you use? If you have a model with an Exercise app, you might get some help by using a different Exercise Shortcut. Also, you can rename an exercise using the Categorize Exercise feature of the app. You won't find Sh'bam, but dance is there.
I haven't found any way to rename an exercise on the web dashboard.
I don't have any insight about creating a custom exercise. I am a lumper, not a splitter. I use Workout on the Exercise app for many types of exercise and leave it at that.
Laurie | Maryland, USA
04-01-2020 04:05
04-01-2020 04:05
Versa lite but I am struggling to understand your instructions
04-01-2020 08:05
04-01-2020 08:05
@Itsreem55 I think a good place for you to start is to read this Help Article How do I track my workouts with my Fitbit device?
I don't know what you mean by body combat, but Martial Arts sounds close. You might want to try your body combat using the Martial Arts shortcut. In my case, if I am going to any type of workout that doesn't fall into one of the categories, I use Workout. If I am doing a dance workout, I tap on tap on the Exercise icon on my Versa 2, choose Workout, then start and so on. When I am done it syncs to the app. On my app, when I tap on my Exercise Tile, then that Workout, the next page has all the details and an option at the top to Categorize Exercise. When I tap on that, I can change it to Dance. The choices are a little limited. Sh'bam is a very specific choice, so it isn't on the list.
Does this help?
10-31-2020 20:32 - edited 10-31-2020 20:38
Is there ever going to be an option to rename all activities - as I run in different locations and they all just store as "run".
To compare like for like runs I have to export data to Garmin connect to review & compare.
If I select workout, so it can be renamed, it does not do GPS.
10-03-2021 19:47
10-03-2021 19:47
Where is this pencil? Why can I not attach a photo without knowing the "Source", "Image Description", and "Dimensions". Why can I not drag and drop a screenshot of my dashboard? But where is this pencil?
10-14-2021 15:01
10-14-2021 15:01
Hi everyone. Thanks for stopping by @FunMarcus.
I'm sorry to hear about the difficulties you experienced to attach the picture and to find the pencil to rename your activities. I suggest trying the following to find the pencil:
To find information how to share pictures in your post you can review this thread.
Hope this helps.
08-18-2022 11:16
08-18-2022 11:16
There is not a pencil next to every activity. As fitbit devices do not have the ability to track rowing, I have to use the spinning or biking tracker instead. I would like to edit the name afterwards to rowing.
08-18-2022 12:58
08-18-2022 12:58
Try using the outdoor workout
CharlesKn | Mid-Atlantic, USA
60+, strength and cardio
Charge 5, Android, Windows
08-18-2022 13:02
08-18-2022 13:02
In the Fitbit dashboard settings for your device, you have to edit the exercise shortcuts to include workout, and have that upload to your tracker.
Then manually start the workout activity on your tracker when you do your workout.
I believe the outdoor workout will add GPS to the activity.
After the workout syncs to the fitbit (web) dashboard, click the pencil icon to rename. Once you create and use a name it will show up as a suggestion later.
I have multiple strength training workouts that I do, all with different names.
08-18-2022 13:03
08-18-2022 13:03
Try the workout, or outdoor workout, activity.
I believe you can edit auto-recognized activities, and the workout activity.
09-04-2022 00:23
09-04-2022 00:23
CIndy's method only rename workout in the history section. Workout is still labelled as workout in the exercise shortcuts section of my charge 5. Is there a way to propagate the change to the shortcuts?
09-04-2022 03:06
09-04-2022 03:06
@domidodo I'm sorry, but you can't change the names of the exercise shortcuts themselves. They are named by Fitbit.
02-05-2023 10:52
02-05-2023 10:52
These are great instructions. Unfortunately they did not work. I wanted to overwrite the auto recognized Outdoor biking activity to skiing and it does not update/save 😞
02-05-2023 15:02
02-05-2023 15:02
@Nomorewaste For some reason, I have found that some exercises will update in the Fitbit app, but not on the fitbit.com activities dashboard. I would try both, and let us know what happens.
03-28-2023 13:20
03-28-2023 13:20
Why would the dashboard not allow you to edit an activity that isn't Workout is beyond me
03-28-2023 14:07
03-28-2023 14:07
@Amstellodamois There have been some relatively recent changes and you rename certain other activities. You can't rename an activity with GPS data to a non-GPS activity, for example. The best thing to do it to look for the pencil in your activities dashboard to see which can be renamed.
