11-14-2014 15:49
11-14-2014 15:49
Winter has returned and today I CX skied for hour & 30 minutes. I was very excited to see how my Fitbit would record this. I was very disappointed when I check......no record, not even active minutes. Could someone out there advise me how, or if possible to do this. I am a very active skier and would like to
keep track of this activity.
SportyGirl
12-04-2014 14:52
12-04-2014 14:52
Thanks for stopping by @SportyGirl! I hope you are doing great today. I wanted to follow up on your post and make sure you were able to log your Cross Country Skiing on your Dashboard by following the recommendation @Sev123 provided?
If so, I invite you to mark @Sev123 post as the solution. Marking posts as solutions is a great way of thanking another community member while also highlighting their solution so that it may be discovered more easily by other community member's facing the same questions or issues as you. You can read more about Accepted Solutions here.
Good luck!
11-14-2014 21:46
11-14-2014 21:46
Hi. You can log your activity and get credit for active minutes and calories burnt. Just go to track exercise and log your time for cross country skiing. It's so great that you are getting outside active time in the winter!
12-04-2014 14:52
12-04-2014 14:52
Good luck!
01-28-2015 10:19
01-28-2015 10:19
I just tried to enter cross country skiing. Unless I put in calories burnt, it wouldn't give me any credit for doing anything. What am I doing wrong?
01-29-2015 05:26
01-29-2015 05:26
@barbjoey I recommend that you try logging this activity using a computer, in case you are using a mobile device. You should see the calories as an optional choice when logging the activity. Here is an example:
Try it one more time and let me know if you still have difficulties logging it.
Thanks!
01-08-2018 10:32
01-08-2018 10:32
Hi,
I skied today ( cross country ) an used the “bike” exercise mode, and I got what I wanted, distance, puls, speed, etc.. ( the gps wasn’t as precise as the other watch I used. But from what I can see at the forum it’s an issue you are working on with the Ionic ) But why cant you make it possible to edit the exercise afterwords from “bike” to “cross country skiing? When I do it, it just jumps back to “bike” after a few seconds.
Is this something that will come in the new updates?
01-08-2018 15:16 - edited 01-08-2018 15:18
My Fitbit flex 2 records my stats when I "track" during cross country skiing but it will only record it as run walk or hike. If I "log" it as skiing does that then double the exercise? Or is there a way to tell the tracker to call it skiing instead?
02-18-2018 15:17
02-18-2018 15:17
How Do I enter cross country skiing into an activity to track on my dashboard?
02-01-2019 08:06
02-01-2019 08:06
Skiing is not a option. Your solution doesn't work.
02-06-2019 09:40
02-06-2019 09:40
There is no solution to this, so how to track xc skiing? List of activities is ridiculously short considering tracking activities is the sole job of Fitbit.
03-06-2019 15:27
03-06-2019 15:27
People have been asking for this for YEARS. They're too busy trying to sell you new models which STILL won't track what you're really doing.
02-17-2020 14:55
02-17-2020 14:55
I agree. My five year old Samsung Gear S2 could track Cross Country Skiing. Super annoying my one year old Fitbit Versa can't.
01-01-2021 13:34
01-01-2021 13:34
I did it using Strava. Fitbit Sense detected my cross country skiing as swimming and elliptical workout. We should really have list of activities expanded broadly.
02-06-2021 20:48
02-06-2021 20:48
It appears this has been a request for years and Fitbit refuses to expand. I suggest buying an iwatch. Apple has every sport known to man listed including cross country skiing
02-17-2021 04:02
02-17-2021 04:02
I am disappointed that a such a smart device as the Sense can start my car, pay for my coffee, but does not offer tracking for cross country skiing. I track my skiing as a hike, use the hike stats to log previous exercise, then delete the hike, otherwise it shows a hike plus cross Country ski..... C'mon Fitbit, you guys gotta do better than that. With such a smart device as the Sense....... Put MORE exercise options for your loyal users.... I really find it annoying to record my skiing manually..... That is OLD SCHOOL TECH.
02-18-2021 15:30
02-18-2021 15:30
Hi everyone!
Thanks for the information shared on your posts and for your feedback. We're constantly striving to improve Fitbit products and services, and we very much appreciate all of the input we receive from our customers. I suggest giving us your idea and suggestion about cross country skiing exercise through our Ideas board.
If you find that a similar suggestion has already been made by another member of the community, you can vote for their idea and add your comments.
See you around.
02-21-2021 07:46
02-21-2021 07:46
Thanks for the encouragement. However, the problem is that cross-country skiing has been suggested for years and polite responses have been made to the effect that Fitbit will consider it. But nothing is done.
Action, not endless words.
Be well!
02-28-2021 18:22
02-28-2021 18:22
no auto recognize? I'm not going to enter cross country skiing exercise details 5 times/wk
01-22-2022 14:53
01-22-2022 14:53
Boggles the mind that Fiibit aren't able to add x-country skiing. Time to shop around and move on to another device 🤨
01-22-2022 14:56
01-22-2022 14:56
Why don't you just say you can't add cross country skiing. There are no suggestions that work. Such posts are completely unhelpful!
