07-18-2017 12:51 - last edited on 07-20-2017 04:46 by MarreFitbit
Hi,
Is there anyway of removing days that you have not worn your fitbit from your stats calculations? I often forget to put it on or don't want to be wearing it and I would like to be able to delete those days so I can see an average of my steps and calorie burn discounting those days.
Thanks
07-18-2017 20:44
07-18-2017 20:44
Welcome to the forums!
If you not wearing it then it only the Calorie burn that's there. The is not way to delete it.
The calories burned are BMR calories. Your fitbit also calculates calories burned for your BMR. You burn calories just by being alive! Even Sleeping. Fitbit includes these burned calories in it's calorie calculations, so even if you did not wear the fitbit, you'll still burn these calories.
Read this
Hope to see you around the forums!
Wendy | CA | Moto G6 Android
07-19-2017 14:57
07-19-2017 14:57
Hi @WendyB,
I think what @Olivia101 is getting at is, days with no steps (due to not wearing), end up bringing down the weekly and monthly averages. Even if the tracker had no data besides calories burned, fitbit will still use that calendar day for step averages.
If that's the case, I don't know of any way to exclude days from the counts. It might be an interesting idea to propose on the Suggestion Board on this site.
