11-06-2018 19:53
11-06-2018 19:53
Interval workout not syncing with Strava. Unable to export .tcx file for the same in windows or ios.
11-06-2018 22:22 - edited 05-20-2021 11:34
Hello @Avinash.K was your intervals recorded with GPS?
If not there will not be a tcx file to export.
11-08-2018 11:18
11-08-2018 11:18
Yes. It was recorded with gps. I did interval runs.
11-08-2018 18:10 - edited 05-20-2021 11:34
Currently only runs and Bike rides recorded with GPS after a sync sent to Strava.
As for not being able to download the tcx file, are you getting any errors
11-09-2018 07:09
11-09-2018 07:09
Thanks Rich. Since it dint get auto exported to strava i tried to get the tcx file. It is showing an error as: ‘The activity could not be downloaded. We are looking into the issue’.
I searched the forums for similar errors and it said there is issue with few windows operating system. So i tried on my iPad as well as my android and it failed in both of these as well with similar error message.
11-09-2018 10:37
11-09-2018 10:37
Have you tried through a web browser, I just downloaded a tcx filter onto my phone using the web.
03-09-2019 17:54
03-09-2019 17:54
03-10-2019 11:11
03-10-2019 11:11
Which one of the two issues above are you asking about, @evillama?
03-14-2019 17:25
03-14-2019 17:25
Had a nice long interval run to see that it is not uploaded to strava. Come to find here that i cannot download tcx as gps was not connected. Been a user of charge 2 for a while now, but sucks to find out everyday that gps has problems. I was running in open field in middle of town. I guess i have to stand and wave my arm around for 5 mins for crappy fitbit to catch gps.
Dont get me wrong, i love my fitbit when it works, but more often than not it has one of these crappy limitations.
03-15-2019 06:54 - edited 05-20-2021 11:35
The TCX file was invented by Garmin specifically to hold GPS data, l with no GPS data there will be no file.
@Santhosh_n swinging the arm around will not be of any help, but will not hurt.
The Charge 2 does not have a GPS, but uses the phones GPS.
There are a few things needed for GPS to work.
On the phone Fitbit notification services need to be running. This is the service that is listening for requests from the Charge 2
The Fitbit App needs access to the GPS.
The Charge 2 needs a connection with the phone. These two are normally near enough that finding a better location for them to communicate should not be needed.
On Android I find most GPS problems with the Charge 2 rectified by restarting the phone and normally GPS is locked on before the phone has completely started back up
Others say restarting the tracker also works, but this requires caring the charging cable and a per source with you.
As usual answering a phone based/connection issue is normally easier if we know the type of phone.
11-22-2019 12:03
11-22-2019 12:03
With GPS enabled on the Ionic, the map data is available within the Fitbit account but it won’t sync the data to Strava and if you try to download the tcx file from the website you get the error ‘The activity could not be downloaded. We are looking into the issue’. I managed to download the tcx file from the iOS app but it contains ‘validation - logId -Could not convert activity log 1.1 to TCX’. It should contain data in xml as it does if I export an exercise recorded using the run or walk exercise. Something isn’t working using the interval workout even though it has the gps data showing within my Fitbit account. This is just a run with an interval timer recorded with GPS on, it should just sync automatically. At this point I’d be happy if it exported manually and imported into Strava manually but I have to enter a manual exercise and all the data and attach a screenshot from the Fitbit app. Not what I expect for the price of the watch, bought for it’s GPS and supposed compatibility with other apps like Strava. If this isn’t fixed next time i’ll get a cheaper Garmin that works!
01-22-2020 05:29
01-22-2020 05:29
I'm experiencing the same problem
"validation - logId - Could not convert activity log 1.1 to TCX"
https://web-api.fitbit.com/1.1/user/-/activities/28206982399.tcx
05-11-2020 04:38
05-11-2020 04:38
I have the same issue, I have an android phone and apple computer. GPS was "On" in "Interval Workouts" before I'd started to do run intervals and I can see the activity in the map in the fitbit dashboard but not in Strava. First of all, I believe this activity should be autodetected as a run and walk interval and sync with Strava. If not, I should be able to export the TCX file and upload myself but none of them is working now. I tried both from Web and Android phone.
Note: I have Versa 2 but I don't think this is related to the product we have.
05-11-2020 15:09
05-11-2020 15:09
@Tolga.A this has been broken for a very long time and I wouldn't count it's going to be fixed.
05-11-2020 17:04
05-11-2020 17:04
05-12-2020 02:44
05-12-2020 02:44
05-12-2020 02:58
05-12-2020 02:58
01-09-2021 02:15
01-09-2021 02:15
Just confirming that this is still an issue
03-11-2021 10:49
03-11-2021 10:49
Yes still an issue. I tried to upload an interval workout to strava with gps data included but no luck uploading otmr downloading tcx
05-20-2021 08:39
05-20-2021 08:39
Have Inspire HR and this Interval Workout still cannot export TCX files !!!
GPS is connected to the phone but completing still will not allow exporting TCX files instead flash a quick error message and nothing happens.
