03-27-2016 16:40
03-27-2016 16:40
03-28-2016 01:03
03-28-2016 01:03
If you manually log a walk it will overwrite the steps, calories and active minutes that were tracked by your fitbit with those calculated for the manual entry so you shouldn't be seeing any double counting.
03-28-2016 04:08
03-28-2016 04:08
Thanks for replying. I'm not manually adding it. It's logging it through recognition of activity and it's also logging it because I use the "Track" option (so I get the map and pace info). So all the info is coming from the Fitbit, not from me. So there are 2 listings under Exercise - 1 for the automatic recognition and another from the Track option.
03-28-2016 04:13
03-28-2016 04:13
When you use the track option it's your phone that's doing the tracking rather than your fitbit and that classes as a manual entry and it's that that's overwriting the fitbit's tracking.
03-28-2016 04:38
03-28-2016 04:38
