05-17-2018 15:16 - last edited on 05-18-2018 10:23 by LanuzaFitbit
Macro percentage split per the app does not match macro percentage split per the website - why is this?
Moderator edit: Clarified subject.
05-18-2018 10:35
05-18-2018 10:35
Welcome to the Forums @la1010101.
That sounds quite frustrating. I'd like to take a closer look at why they don't match, or how. Could you take some screen shots from both ends? That'd let me get a visual on the difference. Also, which one is showing the correct info?
In the meantime, perhaps you could try to log out and back into your Dashboard from both ends, app and web. That will force them to reload all information and might match at that point.
Let me know if you have any further questions.
