01-18-2022 11:25
01-18-2022 11:25
On the dashboard, some of the food log windows no longer display items/graphs - but instead display a request to install Adobe Flash Player.
Since Flash Player is no longer supported/not available, wondering what I need to do to replace sufficient to have FitBit Logs function normally. Any suggestions? Thanks
01-21-2022 10:03 - edited 01-21-2022 10:03
You nothing. Fitbit abandoned that part of Dashboard long ago and without proper update it will never work.
04-13-2022 12:22
04-13-2022 12:22
What are the chances of them removing it just so its out of the way?
10-07-2022 08:30
10-07-2022 08:30
Please upvote the 2014 request Get rid of Flash from the web site - Fitbit Community
It has over 500 votes and is "under consideration"
