09-23-2021 04:07 - edited 09-23-2021 04:09
Hi Guys, do you also experience an issue with Fitbit website for raising suggestions for new features? Link here. I tried to raise a suggestion but the page freezes when I hit Post button. Here is an example of my suggestion (you can try to raise a suggestion with this text):
I would like the calendar notifications to appear bigger on the screen. See screenshot how tiny it is at the moment. Also, the text is truncated - only 14 characters appear. The screen of Versa 3 is nice and big so the notification could be bigger.
Current text is so tiny that it's hard to read. It is also truncated. Only 14 characters are visible.
Versa 3
09-23-2021 18:29
09-23-2021 18:29
Hi @Lizard555 ! Nice to see you around. Thank you for your report and suggestion.
Please try deleting the cache of your browser. If the issue persists, try using another browser.
If you this doesn't improve, please let me know what browser you are using so that our team can have a look at it.
Please try using this link https://community.fitbit.com/t5/Feature-Suggestions
See you around.
09-24-2021 01:35
09-24-2021 01:35
Hi Juan,
I deleted cash but the issue persists. Can you please fix it on your end?
I’ve tried Chrome and IE.
thanks,
Jan
09-24-2021 13:14
09-24-2021 13:14
I've moved this non-hardware issue to the Fotbit.com support.
09-26-2021 18:37
09-26-2021 18:37
@Rich_Laue Thank you for your help, keeping the Community in order.
@Lizard555 Thank you four your reply and further information. Our team has been informed and they will be monitoring the situation and work on a solution for it.
Should I receive further information, I'll be glad to inform you over here.
Hope it gets solved soon.
See you around.
09-29-2021 07:41
09-29-2021 07:41
Any update pls ?
09-29-2021 17:15
09-29-2021 17:15
@Lizard555 Thank you for your message.
Our team has been monitoring your situation, but hasn't update me yet.
Have you tried to post your suggestion on another device ? As on your phone or another pc?
Does it occur there also?
We'll appreciate your feedback to this.
See you around
09-29-2021 23:40
09-29-2021 23:40
Yes, I tried. iOS, Chrome, Internet Explorer. All have the same issue.
09-03-2022 09:25
09-03-2022 09:25
Same Issue here, hit post button and just locks up and get spinning wheel forever.
