10-19-2017 18:24
10-19-2017 18:24
I have a question, does anyone here use two titbits. I have the Alta HR and love it. But I do a lot of water aerobics and while I can enter the time I've worked out in, I lose out on all the steps because I have to remove it while in the pool. I'm thinking of buying a flex 2 just to wear while I'm in the pool.
10-19-2017 18:41
10-19-2017 18:41
@Craftymom68, a lot of people use two or more Fitbit devices, and there is no problem doing that as long as they are different types of devices - you cannot have 2 of the same type on one account. You can wear your Alta HR most of time, and then remove it and put on the Flex 2 for swimming exercise. Then, switch back to the Alta HR after the swimming exercise is completed. Just sync the trackers each time you change them to ensure everything is updated.
