01-02-2016 01:38 - last edited on 01-02-2016 12:03 by AndrewFitbit
The weekly report sent on Monday contains data (such as weight measurements) taken from Monday to Sunday. Assuming you weigh yourself at the same time every day, it will not include the weight lost/gained during the day on Sunday.
Example - if you lose 1lb every day, the Monday report will show a loss of 6lb.
Moderator edit: format
01-02-2016 12:31
01-02-2016 12:31
Hey there @SunsetRunner, welcome to the Community! A weekly report will only include data that has successfully synced to your Fitbit account before the end of Sunday. If you notice a discrepancy with the report, I'd recommend you take some screenshots of the measurements and the weekly report, then contact our Customer Support team so they can take a look.
Hope that helps!
01-02-2016 14:48
01-02-2016 14:48
01-02-2016 16:31 - edited 01-02-2016 16:32
@SunsetRunner Sounds like there might be some confusion here, allow me to clarify. Your weekly report will only include data that has been synced from Monday to Sunday (the report isn't from Monday to Monday so it won't include data for the following Monday).
As far as the the weight difference metric, this is calculated based on where you started and where you ended for that week. For example, if someone started their week at 150 lbs on Monday, then ended the week at 149 lbs that Sunday, your weekly report will show a weight change of "-1".
I'd recommend checking out your weight log on the Dashboard or on the Fitbit mobile app to get a more complete picture of your progress
01-02-2016 22:54
01-02-2016 22:54
