09-27-2016 09:07
09-27-2016 09:07
On January 14, 2016 I set a weight goal of 300 lbs. I recently accomplished that goal (lost 45 lbs). Then, fitbit asked me to set a new goal. When I did, the dashboard now reads "lost 2 lbs". I want my goal progress to go back to my Jan 14 weight and show total weight lost (and keep gaining badges for 45+ lost). There used to be a way to specify starting weight when setting the goal. Now, I cannot figure out how to get back to that setting.
Anyone found a way around this?
09-27-2016 15:02
09-27-2016 15:02
@baileymb124 welcome to the forums! That's totally awesome! 45 pounds is a great accomplishment! Way to go.
However, if you set a new weight goal your Dashboard will definitely reset to the new one. If you wish to keep the old weight goal, remove the input from your Measurement History. Just like this:
If possible send me a screenshot of your weight tile from your Dashboard so I can see what you are seeing. I'll be looking forward to your new comments!
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
