05-09-2017 03:08
05-09-2017 03:08
Has anyone noticed that the weight on the Dashboard weight graph is slightly off? Mine is off by 2lbs as compared to the Logs. I weigh using Aria which syncs the same weight that it shows on the scale to both my Android App and the Dashboard, but when I go into the actual weight graph and click a circle checkpoint, the weight is not the same as it appears in the logs. I weighed myself this morning and the log is reporting accurately exactly what the scale reported, but the graph is off.
05-11-2017 14:45
05-11-2017 14:45
Hello @Twinkle_Toes!
From what you're describing, I'd say that the first thing we have to do is make sure that the Dashboard is loading up correctly. To do this, please log out of your account and then log back in. That should force the Dashboard to reload all information and it should be correct then.
Please let me know how it goes!
05-16-2017 06:18
05-16-2017 06:18
Hello! Ok I did that, logged in and out. But the graph is still showing a difference, in fact it's a 3lbs difference now. The Measurement History section is accurate. Where is the graph getting its data from then? 😕
05-18-2017 12:30
05-18-2017 12:30
Hey @Twinkle_Toes!
I'd like to take a closer look into what is happening. Could you please take a screen shot and then post it in here? That way I'll be able to check exactly what is going on.
Look forward to making sense of this situation.
05-19-2017 06:39 - edited 05-19-2017 06:46
05-22-2017 07:49
05-22-2017 07:49
Hey @Twinkle_Toes! Thank you very much for attaching that picture.
My question in this case would be if the graph on your Android app is showing correctly or if it is the same. Could you please check on this and let me know? That should help me identify what is happening.
Look forward to your reply.
05-24-2017 10:34 - edited 05-24-2017 10:38
Hi Lanuza
Today the scale showed 12st 8.
On the Fitbit android app, it is showing that my weight is 12st 8.7, but on the graph on the app, it says 12st 8.8, so it is slightly out.
But on the website Dashboard, it is showing as 'recent' 12st 8.7, then when clicked into, it says 12st 8.6, then 12st 8.4 on the graph.
Regards,
Krystal
05-30-2017 10:31
05-30-2017 10:31
Thanks for reaching back and being so in-depth about what you see. I will be passing this information on to the team. Whenever we get more details or updates on the matter we will be letting everyone know.
Thanks for your patience and understanding. Let me know if you have any further questions.
