11-22-2018 06:06 - last edited on 11-24-2018 10:45 by MarcoGFitbit
Are there ANY Fitbits that sync with MacBook Pro running OS Mojave (version 10.14.1)?
11-24-2018 10:48
11-24-2018 10:48
Hello @Andywatch123, thanks for joining the Fitbit Community, it's great to have you on board.
I appreciate your participation in the Forums and for posting your question. Please note that you can sync and set up several Fitbit devices with your Macbook Pro. You only need to download and install the Fitbit Connect Software. Keep in mind that if you're setting up a Versa, Ionic or Charge 3, you will need to set them up using a mobile device and the Fitbit app; however, you will be able to use Fitbit Connect to sync them with your computer afterwards.
I hope this information can be helpful, if there's anything else we can do for you, please feel free to reply.
11-27-2018 09:59
11-27-2018 09:59
11-28-2018 01:14
11-28-2018 01:14
@Andywatch123 I'm not a Mac user so can't set you through the process but can give you a couple of pointers.
As mentioned above, you will be able to sync from your Mac but you won't be able to do the initial setup of your Charge 3. For this you will need to use a compatible mobile device (see: www.fitbit.com/devices )
Once set up then, on your Mac, go to http://www.fitbit.com/setup then scroll down until you can select "Mac" and then click on the download button. This will download the fitbit connect software that used to sync your fitbit to the dashboard.
The fitbit guide to using this can be found at: https://help.fitbit.com/articles/en_US/Help_article/1873
11-28-2018 17:12
11-28-2018 17:12
11-29-2018 08:51
11-29-2018 08:51
Hello @Andywatch123, I hope you're doing well, thanks for taking the time to reply. It's nice to see you around too @SteveH, thanks for all your help.
@Andywatch123, I appreciate you have come back and let us know the information on this thread has been very helpful for you. If you need further assistance please let us know, we'll be happy to help.
Additionally, in case you have some spare time, I would like to invite you to visit our Discussions board where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted!
