Hello @AudraLG
- Open the Fitbit app.
- Tap the icon in the upper right corner to go to the account settings.
- Tap on Charge 4 in the list of devices.
- Tap on "Apps".
- Tap on the settings cog next to "Weather".
- The first thing listed should be "Temperature Unit", so tap on that row (where it says "Celsius")
- Tap on "Fahrenheit"
- Tap "Done"
- Tap "Back" in the upper left corner
- Tap "Charge4 " in the upper left corner
- Make sure your phone synced the new setting to your tracker by verifying the sync time is shortly before the current time. If not, you'll need to manually sync (scroll down and tap "Sync Now").
- Verify you see the temperature in Fahrenheit now.
