02-13-2017 16:19
02-13-2017 16:19
Yesterday all my weight recordings changed from lbs to kg. I have gone to my settings and it still shows to record them in lbs. Is this a glitch in the software? It shows the same way whether on the website or on my android ap.
02-14-2017 14:42
02-14-2017 14:42
@calig8r Thanks for joining us! Hey have you tried changing this from your Personal Info Settings? Under units you'll find the "Weight" select the units you'll like to use and then click Submit. After that, make sure you sync your tracker so that the changes become effective.
I really do hope this helps. Keep me posted!
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
02-14-2017 14:42
02-14-2017 14:42
02-14-2017 14:55
02-14-2017 14:55
02-14-2017 16:26
02-14-2017 16:26
AHA! I just found where to change it on the phone ap to make it sync up. Now it is all back to recording in pounds. Thanks so much!
02-15-2017 11:38
02-15-2017 11:38
@calig8r thanks for getting back to me with awesome news! Reading that you're now back on track is like a ray of sunshine.
Let me know if I can be of further assistance, I'll be around!
