09-28-2020 20:17
09-28-2020 20:17
So frustrating. Can not seem to add the flex 2 I just got to my account. Have tried adding with two different phones and using 2 different computers. Using the app with the phones they both show the screen "your fitbit has been found" but then it cuts to the main page and my device hasn't been added. Using the computer it sites a Bluetooth error but I can't even manually find it using the instructions it suggests. I tried to factory rest the fitbit but it still won't work. HELP PLEASE!
09-30-2020 04:24
09-30-2020 04:24
Ok! So an app update came out LITERALLY yesterday and when I downloaded it I could add my fitbit. Hope it works for you guys too!
Best Answer09-28-2020 20:29
09-28-2020 20:29
Which phone do you have and is it on the list of compatible devices? click to see
Best Answer09-28-2020 20:35
09-28-2020 20:35
Yes both phones I tried and the windows 10 on my computer are on the compatible list 😞
Best Answer09-29-2020 10:10
09-29-2020 10:10
PROBLEMA DI TUTTI
Best Answer09-30-2020 03:44
09-30-2020 03:44
Having exactly the same issue.
Best Answer09-30-2020 04:24
09-30-2020 04:24
Best Answer10-24-2020 09:42
10-24-2020 09:42
How did you download the update without the fitbit on your account?
Best Answer10-24-2020 14:11
10-24-2020 14:11
