06-09-2020
07:15
17:08
06-09-2020
07:15
17:08
My flex2 will not sync with updates. I have checked my Bluetooth and it is currently paired. It has been doing this quite frequently, and after messing with it I'm able to get it back for a few days. But goes back to saying device not found?
Hi @Shaunalnp
What steps have you taken so far to troubleshoot this?
i suggest restarting your Fitbit and then restarting your phone and see if that helps.
if that doesn’t work, please delete the app and reinstall it .
hope this helps
Best AnswerOne of the steps that may fix a sync issue is to remove the Flex 2 from the phones bluetooth.
But first try turning bluetooth off and on
Shutdown the phone and restart.
Force stop the Fitbit app and clear its cache
