07-17-2020
10:43
17:08
07-17-2020
10:43
17:08
Is it possible to disable certain metrics that synch like steps and distance but keep heartrate and maybe sleep
07-17-2020 11:06
07-17-2020 11:06
Hi @Lime_green_zip1 - No, there is not way to disable specific data points when syncing.
Best Answer07-17-2020 14:46
07-26-2020 10:44
07-26-2020 10:44
Which tracker do you have @Lime_green_zip1?the Flex 2 does not have the heart rate option.
Some of the trackers the user can customize the display.
When it comes to the app the user can edit the dashboard to show only the info they want to see.
