I found an old fitbit flex 2 in my house and decided to try it out. The clasp that connects it around your wrist is missing. Does that affect it? I can easily substitute it with a button or something but I want to know if it would affect product performance. Also, it doesn’t seem to work all the time. I plugged it in to charge and it lit up and charged for 4 hours and functioned properly connected to the cable, however when I unplug it the lights go out. Help?
Hi @EnergeticRabbit many people would take the pebble out of the band and just carry that around, so anything you want to rig for your band is just fine. Here is the link to the user manual and related articles for the Flex 2 - click to go there. You might want to try a restart of the device, as that usually clears up glitches.
Thank you very much!
