09-08-2017
10:49
16:59
09-08-2017
10:49
16:59
having problems with my fitbit flex. It won't charge, have checked the charger unit, it's working, have cleaned fitbit and done reset, still nothing. Any ideas?
09-11-2017 05:29
09-11-2017 05:29
Thanks for following the steps posted above @alley59! Keep monitoring your Flex and let me know how it continue working. If you're having syncing issues, you can try this procedure.
Hope this helps!
09-09-2017 15:04
09-09-2017 15:04
A warm welcome to the Community @alley59! Thanks for the troubleshoot that you've done. I would like you to confirm that you've done a restart by following these steps. Also, please double check that you're fully charging it.
Hope this helps! Keep me posted.
09-10-2017 04:39
09-10-2017 04:39
cleaned contacts again, reset and charged, it took a little while and kept stopping, seems to not fully make contact suddenly. Now fully charged and working. Not syncing properly at the moment but will wait for a little while to let it settle. Thank you
09-11-2017 05:29
09-11-2017 05:29
Hope this helps!
07-01-2018 15:58
07-01-2018 15:58
I have cleaned the contacts on my fitbit and done a reset, but it is still not charging.
07-02-2018 15:24
07-02-2018 15:24
Nice to see you here @POliverTX! Thanks for sharing your experience with your Fitbit Flex and for trying the suggested troubleshoot. To further assist you, I've created a Support case on your behalf.
You should receive an email from Customer Support at the email you used to register with the Community forums.
Keep me posted if you have any other question.
10-25-2019 05:48
10-25-2019 05:48
I am having the same issue. It died and won't charge at all. I've cleaned the fit bit and the charger. I can't restart it because it's dead. Did you have any luck?
10-25-2019 05:57
10-25-2019 05:57
04-20-2021 10:43
04-20-2021 10:43
I have this problem, how do I do a restart? The link takes me to a page I am not allowed to view.
