05-07-2020
22:46
16:54
05-07-2020
22:46
16:54
I woke up this morning and rolled over and heard a small 'snap' and my fitbit fell off my arm, apparently I has somehow snapped the plastic connector holding my Fitbit to my wristband, and it's not the replaceable one, I don't know what to do about it, I've tapped it together so it works for now but I'm not sure how long it'll last
05-08-2020 06:56
05-08-2020 06:56
Hi @ArtcicEB the plastic connector? Can you show us a picture of it? The connector that holds the band together is a metal composite. The tracker part goes inside the band, but it's not plastic. I used to have a Flex. Anyway, if you could, a picture might help.
Best Answer11-23-2020 11:08
11-23-2020 11:08
Exactly the same issue I think it should be replaced not happy
