I have a Fitbit flex too. I have used it faithfully and not had a bit of trouble with it. Updated my phone last week and now it will no longer sync. Five flashing lights, have done the hard reset on the back pushing it three times within five seconds Nothing works . Please tell me how to get my flex to to charge and sync with my phone
5 flashing lights generally means it is doing an update. Maybe you just have to give it time to finish, wouldn't hurt to leave it on charger during.
Best AnswerHi @LBMflex2 I'd suggest you restart it several times. If that doesn't fix it, it is probably dying sadly.
Helen | Western Australia
Best AnswerOh really? My flex 2 is doing the same thing. I thought I accidentally gave it a heart attack as it has been very dry here and I get shocked by everything… it only started doing it after I updated my iPhone, same as @LBMflex2 …
not sure if I can go back to the older version of my phone but will try that and see what happens 🤞🏻
