08-19-2017
16:52
17:15
08-19-2017
16:52
17:15
Last synced at 10:32 am. It hasn't tracked anything since. I've had to manually put everything in. I've made sure the app is updated, restarted my phone, made sure the bit is fully charged. I've manually reset the bit so it should flip over at midnight tonight.
It this something to do with the latest app update? Is there some other update that's happened?
If it doesn't, what do I do?
08-19-2017 19:01
08-19-2017 19:01
Is your tracker counting your steps but not syncing them over? If so the problem is syncing. Or if your tracker is not even counting the steps I'd suggest you try restarting your tracker at least three times in a row.
If the tracker is counting but syncing isnt happening try this:
Go to your bluetooth settings, unpair the tracker and turn off bluetooth, restart your phone, turn bluetooth back on and try syncing again. Make sure there are no other bluetooth devices close by (within bluetooth range). Interestingly my phone syncs easily with my tracker with my tablet close by, but my tablet wont sync with the tracker if my phone is nearby, unless I turn the phone's bluetooth off.
Let us know how you go
Helen | Western Australia
Best Answer08-19-2017 19:01
08-19-2017 19:01
Best Answer09-25-2019 02:11
09-25-2019 02:11
I know this is solved but here is the email from the peeps at Fitbit incase someone else out there finds the extra steps useful ...
Hello Zoe,
It's my pleasure chatting with you regarding your Flex 2 not syncing.
To continue with your case, please follow the step by step instructions below:
We look forward to hearing from you soon.
Sincerely,
Anna B. and the Fitbit Team
