03-29-2021 19:17 - edited 03-13-2023 18:06
Would anyone like a free black Flex band. It was gifted to me but it is not what I need. It is size small, black in color.
Can mail it to you in Canada.
I figured I would try here before donating it.
Thanks!
04-01-2021 13:29
11-22-2022 11:15
11-22-2022 11:15
I sure could use a new large one, but I'm in New Mexico. I've been having trouble finding a new one that will not break (crack) right away.
I hope you found someone who could use it.
Best Answer11-24-2022 18:40
11-24-2022 18:40
Best Answer11-26-2022 10:21
11-26-2022 10:21
That'd be great! I would pay for postage, but not sure how if you're in Canada.
Best Answer12-10-2022 18:49 - edited 12-10-2022 18:53
I found it and can send it to you. How do I get your address privately so it is not visible to everyone?
I figured it out and sent you a private message. 🙂
Best Answer12-12-2022 09:25
12-12-2022 09:25
I have the little piece that connects the band. Can you measure the band? If it's a small, it won't fit. A large is about 10 inches or 25 or 26 centimeters. If it's a large, let me know. I responded to your private message. Please let me know if you received it or not.
Thanks,
Nancy
