@Kymee12365 - Try restarting your Flex 2. Do it at least three times then clean the contacts on the pebble and charger with an alcohol wipe. Also try a different usb slot or wall charger. Please let us know if any of that helps.
Best AnswerNope, that didn’t fix it. And the battery holds charge for a mere few hrs then on. Need to charge at least twice or more in a single day 😞
