01-09-2020
07:18
17:15
01-09-2020
07:18
17:15
Sunday 5 Jan 2020 - 23,903 steps. Monday 15000 steps, Tuesday 18,000 steps but reset Monday to zero, Wednesday 15000 steps but reset Tuesday to zero and Monday still on zero. Sunday still on 23903 - last time it synced according to app logs before today - which is not true
Thursday have pressed the restart on the charging cable. Having done 5000 steps, it has now reset that to zero. Hopefully it has solved the issue, but I have lost my data I assume - annoying as I am in the middle of a competition which needs steps counted.
Two questions - 1. can someone there put my steps back in or can I do it manually by any chance
2. This appears to be a known issue - has it been diagnosed. What is happening? It was pretty reliable for 9 months, then the last 6 have been rubbish (syncing to a Huawei p20 is now sporadic and pretty rubbish).
Is this a dodgy Fitbit?
01-10-2020 10:56
01-10-2020 10:56
Hello @neilaeleven, welcome to the Community Forums!
Thanks for bringing this to my attention and the details that were shared in your post, I totally understand how frustrating this matter can be for you. To better assist you with this, can you please let me know when was the first time you experienced such situation and how many times since then? Only steps are being erased or other stats were affected too? If you haven't already done so, please try the following steps and let me know if the issue persists:
Also, to manually log the information that was unfortunately lost, please check our help article: How do I add, edit, or delete Fitbit data and activities?
Keep me posted.
01-08-2022
23:47
11:46
01-08-2022
23:47
11:46
Every time I sync my watch to the app it resets the step count back to 128.
move worn it all morning and clocked up over 8000 steps and then synced it to the app and it dropped back down to 128?!
I have deleted app and reinstalled. Disconnected watch and reconnected. Any ideas as to why this could be happening?
