Hi @Bezzell these are set to sync when there is activity and is considered to be all day sync. You can't change that, but you can always manually sync if you want to.
@Bezzell check out this article on how to make your battery last longer - click to go there. If you're not using notifications, you could even log out of your app, which would save even more battery power.
