05-24-2020
20:57
17:08
05-24-2020
20:57
17:08
I just purchased a new Fitbit flex 2, as my one from 2016 has been acting up
Can I have them both running at the same time, or will the new one pick up last 4 years info automatically?
The new one will take over for the old one as long as you use the same email address to set it up
You can not have 2 of the same model on the same account though
Wendy | CA | Moto G6 Android
First if they are both flex 2..... how do I take the first one off the account to add the new one?
do I need to let the old one run out of power before this one will sync?
Fully charge the new one got four white lights after taking out of charger get one blinking blue light and cannot get it to go away went out of charger....
put it back in the charger and hit the reset button three times within five seconds all three vibrated and after the third did the quick blinking lights before going back to four white lights
Took out of charger again only blue slow blinking light
Took the app off my Iphone turned off my IPhone 7 Plus and turned back on...Reloaded the app but the blue light will not go away. Repeated the first part about resetting it in the charger and still not syncing
Best Answer@Naneki3 No, you don't need to let the battery drain before you sync.
