07-29-2021
00:47
16:27
07-29-2021
00:47
16:27
I bought a used Fitbit w/o charger, in having trouble figuring out which one I have...it has metal band that's rose gold...ive bought 2 chargers now that don't line up with the dots on the back...any suggestions?
Hi @Cortneyk take a look at the pictures on this - click - page. Pretty sure you don't have a Flex or Flex 2. Rose gold was used in a few of these devices. You could go to a retailer, like Best Buy, to see if they can help you find the right charger.
Hi, @Cortneyk if you're unable to identify your tracker from @Odyssey13's link, we can try this another way. If you share a picture of it in your reply it'll be easier to help you figure out what kind it is. If the tracker is over an inch wide and the bezel is also rose gold it's most likely the Fitbit Versa. If the tracker itself is about half an inch wide and completely black, it's the Inspire.
