11-26-2017
17:35
17:15
11-26-2017
17:35
17:15
I want to set a calorie goal for each day instead of using the food plan. How do I delete the food plan I have set up? I know it can be done, I just don't remember how to do it.
12-03-2017 06:26 - edited 12-03-2017 06:31
Hi
On the food log page (fitbit.com), by 'food plan', click the left arrow once to change the food plan to 'plan summary'. Click the 'edit plan' button which appears.
* When using a fixed calorie goal for the day instead of a deficit, the calories will stay the same and don't update when exercising more. This can lead to burning to many calories and eating to little. Be mindful when doing so, when truly hungry = eat.
Hi
12-03-2017 15:31
04-20-2019 14:57
04-20-2019 14:57
The edit button turns pick when I hoover over it, but won't do anything when I click on it.
05-18-2019 23:48
05-18-2019 23:48
Same for me. So how do we fix the problem?
05-18-2019 23:49
05-18-2019 23:49
It doesn't work for me. How do I delete the food plan if the edit button doesn't do anything?
06-05-2019 17:13
06-05-2019 17:13
I have not received an answer to this problem. When I hoover over the edit plan, it turns pink, but won't go anywhere else. No editing allowed.
06-27-2019 10:25
06-27-2019 10:25
How can this be the Accepted Solution if it doesn't work for anybody but you? Button turns pink but nothing happens. Tested in 3 different browsers on Windows 10 PC.
09-18-2019 04:06
09-18-2019 04:06
This has been irritating me for weeks. Finally figured it out today. To delete food plan tap on the weight tile, edit goal, and tap maintain instead of lose. It cleared my food plan.
09-18-2019 20:23
09-18-2019 20:23
03-07-2020 09:21
03-07-2020 09:21
the edit plan button isn't working but even tho' I'm eating more than the plan says I should (because I'm hungry), I'm still burning more calories than taking in. The algorithm doesn't take that into account and says I'm over my limit.
03-07-2020 09:23
03-07-2020 09:23
thx that worked perfectly!
12-22-2021 03:43
12-22-2021 03:43
That only lets you edit, not delete. I want to remove the food plan as though I’d never set one.
08-16-2022 20:40
08-16-2022 20:40
If you go to here: https://www.fitbit.com/weight and remove the weight goal it kills the food plan.
